Shoppers are floored cucumbers come in plastic but courgettes don’t
Full frame image of supermarket display of plastic crate containing pile of shrink-wrapped, ripe, green cucumbers (Cucumis sativ
Cucumbers come wrapped – but why don’t courgettes? (Stock Image) (Image: Getty)
The supermarket can be bewildering, with certain fresh produce encased in plastic while others remain completely bare.
But have you ever paused to consider why cucumbers are shrouded in plastic while courgettes aren’t, despite being remarkably similar?
One woman turned to Mumsnet to question: “Am I unreasonable to wonder why single cucumbers from the supermarket come wrapped in plastic… but single courgettes don’t?”
She then shared her thoughts on the absence of wrapping, stating: “If you ask me, courgettes have a slightly more fragile skin than cucumber… so why the lack of protection?”
According to chef and author Jessica Gavin, the plastic covering around cucumbers fulfils multiple functions, and people had no idea.
READ MORE: Dog health alert given to all owners as they’re warned ‘don’t ignore it’
She explained in the caption of a video shared on social media: “It helps protect the delicate cucumbers from bruises and damage during transit.” It also helps “extend the shelf life” by “maintaining optimal moisture levels”.
The plastic wrap is also a “hygiene barrier, safeguarding the cucumbers from external contaminants”.
In the Mumsnet comments, someone remarked: “I think it’s because people use the whole courgette at once and often buy more than one.
“Whereas you might want to keep the cucumber for longer and just eat a bit at a time.”
Another concurred, adding: “The plastic wrapping on the cucumber is specifically there to help preserve it in a decent condition for longer because I would suggest most people don’t use a whole cucumber in one go. On the other hand, courgettes tend to be bought for immediate use.”
Some other person commented: “If you have a sliced cucumber without any wrapping, then they tend to wither quite rapidly. I’ve never experienced that issue with a courgette.”
A Mumsnet user contributed: “I believe when I remove the cucumber from the plastic it loses colour more quickly. It keeps reasonably well still, though; it simply doesn’t appear as vibrant and appealing.”
Some adopted a firm position regarding plastic-wrapped vegetables, nevertheless, insisting that it ought to be “prohibited”.
They declared: “The initial thing I do with a cucumber is remove the plastic and dispose of it. It gets kept in the fridge ‘unwrapped’ even after I’ve sliced it.
“If the tip is somewhat dried out or withered when I next use it, I trim a piece off and either consume it or discard it.
“I believe plastic wrapping on fruit and vegetables ought to be prohibited, and I decline to purchase it if I can help it, but certain items only come pre-packaged nowadays.”
Someone else enquired: “Does the plastic help them keep longer in the fridge? I assumed it was for supermarket storage life. I discovered mine appear to spoil in the plastic, so I have begun removing the plastic before placing them in the fridge. Am I mistaken?”
Leisure centre, UK charity and two more enter administration
Several UK companies, including a leisure centre, have plunged into administration recently (Image: Getty) A …
