Pension savers overcharged £61million in tax due to ‘ludicrous quirk’ of system | Personal Finance | Finance
Savers reclaimed a record £61 million in over taxation on pension withdrawals in July, August and September this year – the highest three-month figure since records began.
Savers are getting up to £3,252 back on average after being hit with a bloated tax bill.
Since 2015, HMRC has chosen to tax the first flexible withdrawal someone makes in a tax year on a ‘Month 1’ basis.
This means HMRC divides one usual tax allowance by 12 and applies them to the withdrawal, landing hard-working savers with shock tax bills often running into thousands of pounds.
While those who take a regular income or make multiple withdrawals during the tax year should be put right automatically by HMRC, anyone who makes a single withdrawal will likely be left out of pocket.
An expert has argued that this “ludicrous quirk” of the tax system is affecting more savers than ever.
As the cost of living crisis continues, many older savers are opting to withdraw from their pensions, leading them to be hit with a “with a bloated tax bill”.
Tom Selby, head of retirement policy at AJ Bell said: “This forces them to go through the rigmarole of claiming their own money back has always been unfair, but it is particularly cruel given the financial challenges millions of people are facing today.
“It is ridiculous the government has failed to adapt the tax framework to cope with the fact people are able to access their pensions flexibly from age 55, instead persisting with an arcane approach which hits people with an unfair tax bill, often running into thousands of pounds, and requires them to fill in one of three forms if they want to get their money back within 30 days.”
Despite savers reclaiming £61 million in the latest quarter, it is likely the true over-taxation number will be substantially higher.
In particular, people on lower incomes who are less familiar with the self-assessment process might be less likely to go through the official process of reclaiming the money they are owed. As a result, they will be reliant on HMRC to put their affairs in order.
Speaking on how savers can avoid a big bill after a single withdrawal, Mr Selby suggested taking a notional withdrawal first.
He said: “To potentially avoid the shock of a big over-taxation bill is by taking a notional withdrawal first. This should mean HMRC is able to apply the correct tax code to the second, larger withdrawal.
“Alternatively, you can fill out one of three HMRC forms and you should receive your tax back within 30 days. If you don’t do this, the Revenue says it will put you back in the correct tax position at the end of the tax year.”
How to get your money back if you are overtaxed
Those receiving a steady stream of income via drawdown shouldn’t need to take any action, as HMRC will adjust their tax code to ensure that over the course of the year, they are taxed the correct amount.
However, if someone makes a single withdrawal then they will either need to fill out one of three forms or rely on HMRC putting them in the correct position at the end of the tax year.
Which form people need to fill out will depend on how they have accessed their retirement pot:
  • If one has emptied their pot by flexibly accessing their pension and is still working or receiving benefits, they should fill out form P53Z,
  • If one has emptied their pot by flexibly accessing their pension and isn’t working or receiving benefits, they should fill out form P50Z,
  • If one has only flexibly accessed part of their pension pot then use form P55.
Provided people fill out the correct form HMRC says, they should receive a refund of any overpaid tax within 30 days.
Tax warning over pension withdrawals as HMRC cracks down | Personal Finance | Finance
Workers dipping into their private pension pots have been warned they could end up facing …
