Expert dermatologist’s anti-ageing solution targets wrinkles and dark circles
Age, everyday stressors and UV exposure can all cause damage to the skin, but a skincare routine can help maintain a healthy complexion.
It’s not only those worried about ageing who struggle with changes in the appearance of their skin, as fatigue can also have drastic effects, causing dullness and dark spots.
Although nothing’s going to replace a good night’s sleep or take your skin back in time, there are products that can help to give it a boost.
Developed by dermatologist Dr Tiina Meder, the Blepharo-Light Eye Cream has been formulated to improve the skin around the eye.
To keep the eye area bright and radiant over the winter months, Meder Beauty are offering 15 percent off with the code BL15 until January 1.
Buy: Blepharo-Light Eye Cream (£43)
The skin under the eye is one of the thinnest, most delicate parts of the body and therefore can be prone to ageing and discolouration.
Keeping the area hydrated is key, and the Blepharo-Light Eye Cream contains caffeine and niacinamide to brighten and energise the skin by drawing in oxygen.
Eyeseryl – a complex peptide, helps to boost collagen production which can plump the skin and reduce lines and wrinkles.
Created with a gel-like consistency, the cream delivers an instant cooling effect, and quick absorption.
Although the cream can help improve the appearance of the surface of the skin, the results may not be instant, and it’s recommended to use once or twice a day, with consistent use.
The cream is described as suitable for all skin types, but it’s worth keeping in mind that it may need to be combined with other products to achieve results on more mature skin.
Premium skincare is a costly investment, but luckily there are cheaper alternatives out there.
The e.l.f. Holy Hydration! Eye Cream also contains peptides plus hyaluronic acid, but it’s an affordable option that will only set you back by £10.
Pamela Anderson and Princess Kate’s handbag has £100 off
If you’re thinking about investing in a handbag that will genuinely stand the test of …
