Apple Watch gets new Sleep Score feature for better sleep tracking
Apple added a new Sleep Score feature that gives you a single number to sum up how you slept.
It pulls data from your Apple Watch and turns it into an easy rating you can check first thing in the morning. This makes it much easier to understand your sleep without sorting through charts.
Sign up for my FREE CyberGuy Report
Get my best tech tips, urgent security alerts and exclusive deals delivered straight to your inbox. Plus, you’ll get instant access to my Ultimate Scam Survival Guide — free when you join my CYBERGUY.COM newsletter.
System requirements for Apple Watch Sleep Score
You need an Apple Watch running watchOS 26 or later paired with an iPhone running iOS 26 or later. This feature was tested on an iPhone 15 Pro Max and an Apple Watch Series 11. If you run older software, update your devices before you begin.
iPhone: Settings > General > Software Update > Install iOS 26
Apple Watch: Watch app > General > Software Update > Install watchOS 26
hands holding apple watch
Apple CEO Tim Cook holds up the new Apple Watch Series 11 during a launch event at Apple Park in Cupertino, California, on Sept. 9, 2025. (David Paul Morris/Bloomberg)
How to set up sleep tracking on your Apple Watch
It only takes a minute to get your Apple Watch and iPhone working together to monitor your nightly sleep habits. Here’s how to do it:
  • Open the Health app on your iPhone.
  • Tap the Search icon in the bottom right of the screen, then choose Sleep.
  • Tap Get Started, then tap Next if you haven’t set it up before. Otherwise, click Sleep again.
  • Scroll down to Your Schedule and click Add to set your Sleep Goal by tapping where it says BEDTIME and WAKE UP
  • Choose the days you want this schedule active, then tap Add.
  • You can always revise it by clicking Edit.
Once your Apple Watch sleep tracking is set up in the Health app, the Sleep Score appears in both your watch and iPhone. You can view your history and see how your habits change over time.
How to check your Sleep Score on Apple Watch
You can see your Sleep Score right on your Apple Watch as soon as you wake up. The score usually appears within about fifteen minutes and gives you a quick look at how you slept. Here are the steps:
  • Press the Digital Crown to open your apps
  • Open the Sleep app
  • Tap the i in the circle next to your Sleep Score once it appears. Then tap the X.
  • Use the crown to scroll down to view your Sleep Stages, Time Asleep, and Last 14 Days.
  • Open the Health app on your iPhone for full charts and history (see below for steps).
This keeps everything fast and simple on your wrist while your iPhone shows the deeper breakdown.
ADAPTIVE POWER IN IOS 26 BOOSTS IPHONE BATTERY LIFE
How to check your Apple Watch sleep score on iPhone
Follow these steps to see your score each morning:
  • Tap the search icon in the bottom right corner
  • Select Sleep
  • Tap Sleep Score
  • Tap Sleep Score again to view more details
  • Choose Show in Charts to track your score over time
  • Pick W for weeks, M for months, or 6M for six months of history
  • Look under Levels to see how many nights fell into each score range
  • Select Elements to check your average duration, bedtime, and interruptions
  • Tap the info icon to learn what each Sleep Score level means
woman sleeping
Apple’s new Sleep Score feature gives users a rating each morning to show how well they slept and met nightly goals. (iStock)
How your sleep score works
Your Sleep Score is a number out of 100. Apple uses three main factors to build your final rating. Sleep duration provides up to 50 points. Bedtime consistency offers up to 30 points. Interruptions and wake-ups make up the last 20 points. These elements combine to show how close you came to your nightly sleep goals.
When Apple calculates your score, it places you into one of five levels. These levels help you understand the quality of your rest. They may not always match how you feel in the morning, but they give you a steady way to track trends over time.
Excellent Your body and mind likely received the rest needed for the day. With consistency, this level may also support long-term health.
High You may not have slept perfectly, but you got the sleep you needed. Your night was likely restorative and may still benefit your health over time.
OK An OK score often means your body and mind did not get the full amount of rest they need.
Low A low score means you did not get enough time to rest and restore.
Very Low A very low score suggests your body did not get the sleep it needs. If you see this level often, it can affect your mental and physical health.
APPLE RELEASES IOS 26.1 WITH MAJOR SECURITY IMPROVEMENTS AND NEW FEATURES FOR IPHONE USERS
Take my quiz: How safe is your online security?
Think your devices and data are truly protected? Take this quick quiz to see where your digital habits stand. From passwords to Wi-Fi settings, you’ll get a personalized breakdown of what you’re doing right and what needs improvement. Take my Quiz here: Cyberguy.com
Photo of a man wearing an Apple Watch on his wrist.
An Apple Watch running watchOS 26 pairs with an iPhone on iOS 26, or later, to track nightly sleep habits. (Apple)
Kurt’s key takeaways
The new Sleep Score makes the Apple Watch’s sleep tracking easier to read and more useful day to day. You get a clear number that shows how your routines guide your rest. If you want a quick pulse check each morning, this tool keeps things simple.
What part of your nightly routine affects your score the most? Let us know by writing to us at Cyberguy.com.
Copyright 2025 CyberGuy.com. All rights reserved.
KAIST humanoid robot runs, kicks and moonwalks in real-world field test
NEWYou can now listen to Fox News articles! By now, you’ve no doubt seen humanoid …
