£1.42 teeth whitening solution makes teeth look ‘whiter than ever’ with ‘no sensitivity’
Over time, it’s easy for teeth to get built up with stains and become discoloured or lose brightness.
Consuming tea, coffee, wine and strongly coloured foods can lead to yellowing, and many search for ways to reverse it.
While professional teeth whitening can be effective, it can also be extremely costly, but luckily there are solutions that can be used at home.
Customers of HeySmile have found its teeth whitening strips to be effective and easy to use, with the at-home product racking up hundreds of reviews.
There’s currently an offer on to get the strips for £19.99 instead of £29.99, and with 14 sets of two strips – one for the top teeth and one for the bottom – each full application works out at £1.42.
Buy: HeySmile Teeth Whitening Strips (£19.99)
The gentle formula of the strips uses PAP, which is proven to whiten teeth but is also non-toxic and peroxide-free, avoiding sensitivity and gum irritation.
To use the strips, the process is simple, first you brush your teeth, dry them and then place the strips on the lower and upper teeth. After 30 minutes, remove the strips and brush the teeth to remove any excess residue.
The teeth whitening strips claim to work after just one use, which some reviews agree with, while others say that more consistent use gave the best results.
Generally the formula shouldn’t cause sensitivity, however some reviews do mention they could feel a slight tingle on application.
Shoppers are commenting on the teeth whitening solution, with some saying their ‘confidence in smiling has improved’.
Amber-Jade G said: ”Works perfectly, saw changes from first use, teeth look whiter than ever. Would recommend to anyone.”
Sam M commented: ”The whitening strips were easy to use and worked well with no sensitivity.”
Jane P said: ”Stains never appear since using this. My teeth are definitely whiter. My confidence in smiling has improved. Even my dentist was impressed.”
Joanna M also added: ”Goods arrived quickly. Have seen an improvement in whiteness of teeth already. Still have half the pack to use. Decent product, decent price. Slight tingle when first put on, but that doesn’t last long at all. I find it easier to do top and bottom rows of teeth separately.”
‘I’m a TV nerd and there’s a psychological thriller you need to watch’
Netflix users have been urged to watch the “biggest hidden gem” on the streaming platform …
